CODING the F56 MINI - Can someone help me?
  • I didn't test the settings. Therefor I'm not sure which setting will make it (tms_leuchtring or tfl). You'll have to try out yourself.
    No problem, thanks!!
    Is there any risk that changing those settings could cause something to go wrong?? ?(
  • You can always undo the changes and go back to the original settings.
    It would be a good idea to write down what you changed.
    When your dealer loads new software in your car all codings will be removed.
    Toll wie gut, nein sehr gut, Du die Englische Sprache beherrscht. Komplimente. :thumbsup:
    Englisch ist nich mein Ding/Sache.
  • Tried the coding today and it did not work! :(
    Thanks for the suggestion though @HASR60
    We managed to get the rear lights to work when the front DRL is working.
    We could not get the LED DRL to operate as the sidelight though....
  • @R99 Can you please help me:
    I'm hoping you can help me with which changes are needed in esys to achieve the following??
    1) remove fog lights
    I just removed the foglights from the bumper.
    The foglights in the bumper included the german „Standlicht“ or englisch sidelights.
    The headlights on my car are LED headlights with an incorporated DRL LED 'horseshoe' ring.
    DRL ring as its sidelights instead of the separate unit in the lower bumper like on the Cooper S.
    i AM JUST HAPPY IF THE SIDELIGHTS WERE IN THE DRL LED RING!!!
    Do you have the changes?
    PERFECTLY would be the following:
    1) headlight position switched to 'off' = EVERYTHING OFF
    2) headlight position switched to 'sidelight' = LED DRL in headlight ON / rear lights ON
    3) headlight position switched to 'on' = NOW EVERYTHING IS OK
    4) Switches Auto = everything ok
    So in basic terms, I want my car to use the LED DRL's [which are built into the headlight] as the side lights, since my Cooper S will no longer have the fogs / sidelights in the lower bumper...
    Can anyone shed any light on this?
  • @Pastis
    Danke aber einen Versuch war es wert.
    Vielleicht bekommt er ja ne email Benachrichtigung.
    @HASR60 oder @HASR90 scheint auch nicht mehr an Board zu sein, lässt sich zumindest nicht verlinken.
    @dribbleggs hätte auch noch helfen können aber der scheint auch inaktiv zu sein. Alle codierer offline
