Hi,
i took a closer look on your pictures @r0b3r. On the left picture you can see that the muffler admission is on the right bottom. If you turn arround the right picture you can see that the Muffler admission is on the left bottom. So I can't see an easy opportunity to fit it to an F56 without welding
I don't exactly get what you're trying to tell him. But those are round shapes, you can turn them and a bend to te right becomes a bend to the left quite easily?!
@r0b3r, if you had to cut the exhaust and weld it, I can imagine the approval is not valid anymore. Just buy a fitting one, much easier.
