Hallo Miteinander..
jemand das hier schon verbaut und gibt es auch Lösungen mit Eintragung wie "Eventuri" und CO ?
Wenn verbaut... merkt man was oder ist es nur ein Hingucker.. !?
https://www.awe-tuning.com/mini-cooper-f5x-sflo-intake
Presenting the AWE MINI F5X S-FLO Carbon Intake:
- Max gains of 9 hp and 10 ft-lbs of torque to the crank
- 30% increase in airflow over stock
- Features a billet aluminum MAF fitting, and AWE’s washable S-FLO Filter
- Carbon fiber heat shield design keeps things cool while unleashing intake sounds
- Composed of 3k, 2x2 twill carbon fiber with a UV-stabilized resin
- Carbon fiber construction lowers thermal conductivity versus metal heat shields
- Perfect integration with OEM inlet ducting to utilize ram air from grille
- Retains factory mounting and MAF location for trouble-free operation and OE-like fit
- Designed, engineered and tested in-house at AWE
- No Check Engine Light Guarantee
- Perfect Fitment - Guaranteed
